F-4 Phanton é arremessado contra muro de concreto [VIDEO]
San Andreas
The purpose of the test was to determine the impact force, versus time, due to the impact, of a complete F-4 Phantom — including both engines — onto a massive, essentially rigid reinforced concrete target (3.66 meters thick). Previous tests used F-4 engines at similar speeds. The test was not intended to demonstrate the performance (survivability) of any particular type of concrete structure to aircraft impact. The impact occurred at the nominal velocity of 215 meters per second (about 480 mph). The mass of the jet fuel was simulated by water; the effects of fire following such a collision was not a part of the test. The test established that the major impact force was from the engines. The test was performed by Sandia National Laboratories under terms of a contract with the Muto Institute of Structural Mechanics, Inc., of Tokyo. To view and download footage or still photos, click on the links or the images below.
FOTOS
http://www.sandia.gov/images2005/f4_image1.jpg
http://www.sandia.gov/images2005/f4_image2.jpg
http://www.sandia.gov/images2005/f4_image3.jpg
Kam
engraçado que não sobra praticamente destroço nenhum do avião, imagina carregado de combustivel.
hknoener
Under construction...
Carácoles, a parede abduziu o bicho!
ByPeters
Like a Boss
Alguém sabe o tipo de material que é usado nessa parede ?
OGAIHT
Se o WTC fosse revestido com o mesmo material desse muro, os terroristas dos aviões estariam estampados nas paredes até hoje, iguais a "chiclés colados"
:D
Renzo
Membro
:D
uhuahhuAHuaHuaAUaH
Vou construir minha casa no terreno que comprei, acho que vou por desse murinho ae x)
AgenteZua
/AutoBan mode on
:D
Mas sera que nao ficaria muito pessado um predio daquele tamanho com umas paredes destas???:rolleyes:
