analise de camera IP fullHD
_bono_vox_
www.rn2.com.br Loja online
Estou analisando uma camera que pelo review que vi na net, parece exelente
trata-se dessa camera abaixo
( comprei desse site recomendado por gringos e elogiado pelo suporte, alem de frete gratis ao brasil )
http://www.securitycamera2000.com/products/1080P-Outdoor-IP-Camera-with-5-Megapixel-sensor-40m-IR-Night-Vision.html
Features:
1/2.5'' 5 megapixel CMOS Color Sensor
TI DaVinci DM368 DSP
Main stream: 2 MP:1920×[email protected] fps; 3 MP:2048×[email protected] fps; 5 MP:2592×[email protected] fps
H.264 video encoding, AVI format
Support the motion detection
2pcs high power IR LEDs
40m night vision
Unique Waterproof IP66 Design
Aluminum Alloy Shell in Whole Machine Casting
Perfect Thermal Conductivity & Stability
DC [email protected] Power input
Support ONVIF 2.2 compliant( Upgrade firmware)
Support IPhone/Android phone viewing
Support iphone /ios android mobile remote APP: Tsee (NAT 4 Port web:80 RTSP:554 mobile:556 data:8091)
There are 4mm, 6mm, 8mm, 12mm and 16mm lens for optional, by default, we will ship out 8mm fixed lens.
Color: Gray and Silver for optional, by default we will ship out silver one.
Note:
CVBS and BNC video output are invalid for now.
It supports Window XP/Vista/7 32bit/64bit and IE 6.0, IE7.0 and IE8.0 browser only. The power adapter is not included in the package, we recommend you this one: AC 100-240V to DC 12V 2000mA Power Adaptor (PZ0374).
Real-time resolution 2MP: 1920 x [email protected]; Lens parameter 3MP; Sensor parameter 5MP, not suitable for long time use.
review completo http://blog.quindorian.org/2013/03/ipq1649x-1080p-outdoor-ip-camera-with-5.html
imagem de dia https://www.youtube.com/watch?v=blkVFnIvLsc
imagem a noite https://www.youtube.com/watch?v=ouY3FDkzNUw
pretendo fazer um review nacional para nós quando chegar o produto.
nao estava satisfeito com o sistema analogico que usamos em nossas empresas e estou entrando no mundo das cameras IP´s de alta definição.
claro que temos uma boa internet e estrutura de rede para suportar isso
comentarios sao bem vindos :awesome:
dani5lo
temet nosce
acompanhando o topico...no aguardo do seu review meu brother!!
ph0b0s
Somo dois ! Ainda aguardando o review !
darktag
PC Gamer
Acompanhando o tópico.
_bono_vox_
a camera chegou.........e vou contar a voces............é muito boaaaaaaa! a imagem é incrivel.
estou fazendo testes ainda.
darktag
PC Gamer
Encha o tópico de fotos, comentários sobre as características, onde comprou, com quem comprou, etc.
_bono_vox_
comprei neste site
frete gratis, chegou em quase 2 meses
fui taxado pela receita, mas os vendedores gringos perguntam quanto vc quer declarar na caixa, eu pedi 42 dolares
fui taxado em 50 reais pela receita...no brasil uma camera potente como essa nao custaria menos de 900 ou mil reais.
to com um projeto de cameras digitais, uma empresa pediu 30 mil reais, eu importando e montando meu sistema sai por 8 mil
as fotos posto em breve
darktag
PC Gamer
comprei neste site
No aguardo :awesome:
[leo]
Tem garantia essa câmera? Minha preocupação de trazer produtos lá defora são as garantias.
jtedaldi
És Fuedas
Muito bom amigo, nao conhecia este site. Os preços sao muito bons perto do que vejo da alixpress e ebay.
Você esta usando algum gravador para a camera?
crunk
Somewhere around ...
Putz que bela definição em, curti demais. Esperando seu parecer gogogo :joia:
_bono_vox_
eles dao garantia sim, eles trocam em caso de defeito, ja vi um gringo relatando que eles dao total assistencia aos clientes.
ainda nao estou usando gravador na camera, a ideia é usar um dos meus servidores dedicados para gravar as imagens via soft da camera.
a imagem em fullhd trava demais por consumir muita largura de internet, mas para analisar imagens gravadas é otimo demais.
para visualizar ao vivo recomendo ver em baixa resolução para melhor fluidez das imagens.
o firmware da camera acredito que tenha que atualizar, as vezes da uma travada e tenho que reiniciar.
ela vem com um tipo de linux embutido pelo que li.
DanielAni
Fast and Furious
Fica inviável então com nossa net porca?
O adianta ser fullHD se precisa baixar resolução por causa da banda? :hmm:
_bono_vox_
adianta para analise de imagens gravadas em hullHD , que ai rola um zoom digital e imagens cristalinas.
para ver ao vivo pela internet fullHD nao rola, fica 1 FPS a cada 3 ou 5 segundos kkkkk
Ver pela rede interna rola de boa o fullHD
Tem que ter um upload de 10 megas para rolar de ver pela net UMA camera dessa em fullhd com uma certa suavidade.
Aqui com 50 megas de down e 6 de up, ta travando....mas em resolução menor fica bem suave.
Sexta eu posto umas imagens, por sinal, sao muito boas.
Roman
A parte da estabilidade preocupou... Ter q reiniciar a câmera definitivamente não rola...
_bono_vox_
agora ficou mais estavel e mesmo pela internet a imagem esta bem mais fluida , tipo 1FPS por segundo a 2 FPS
segue imagens da qualidade
Jarbasafa
Undead Rogue
qualidade muito boa!
Vinicius Fernandes
Bono, preciso muito de uma ajudinha sua.
To pensando em comprar essa camera para colocar no sitio so que nao sei se ela e compativel com o SurveillanceStation.
Tem como me passar seu email para ver se tu consegue me ajudar
_bono_vox_
posta aqui a duvida, que ja ajuda demais usuarios futuros.
eu nao conheço ainda o SurveillanceStation
Vinicius Fernandes
entao o SurveillanceStation e do synology.
Eu tenho um aqui em casa ai eu preciso saber se ele e compativel com ele.
Voce consegue compartilhar ele atraves da internet para eu tentar configurar aqui para ver se funciona.
E so colocar no ddns
mninja
Configurei um server com zoneminder em raid 5 numa VM, 18 câmeras em [email protected] fps em alarme 5 em idle, ele não deu conta, imagina 10 câmeras dessas! O cara ia ter que fazer um storage de SSD pra dar conta do volume de dados.
_bono_vox_
fato :fovhappy:
ela é boa para um local que precise de uma imagem top em especial para analise, nao rola usar em todos os locais nao
mninja
fato :fovhappy:
pois é eu tive que abaixar a resolução pra 320x240 e as duas da entrada/saída deixei em 640x480. Olha uns prints aí:
Specs da config:
Gravando apenas em movimento. Idle 5 fps, em alarme 25 fps.
Servidor: VM em um xeon com raid 5. Com 4 virtuais e 3gb de ram. Partição para os vídeos de 400GB.
Alguns eventos gravam um pouco 'travados', mas já deu pra flagrar alguns delitos, aos poucos vamos aperfeiçoando. Mas a ideia é que tudo seja migrado pra uma solução dedicada de CFTV em 6 meses.
ah o principal, as câmeras!
16x axis p1343
2x m1011
_bono_vox_
manda um print das imagens em si , para ter uma noçao da qualidade da camera
