+ Responder o Tópico
Mostrando resultados 1 até 6 de 6
Tópico: Winamp 5.2 Beta
  1. Avatar de MrDuckGod
    MrDuckGod é offline Mr. DuckGod MrDuckGod está em um caminho distinto
    Data de Entrada
    Feb 2005
    Local
    Curitiba
    Mensagens
    1.664
    Winamp 5.2 Beta
    What's News in Winamp 5.2 Build 393
    * Fixes a memory leak when using playlist winshade mode in the modern skin
    * Fixes in_mp3 security hole
    * Added experimental skin-colored icons to media library tree
    * Changed the "Devices" parent node (in media library) to "Rip & Burn"
    * Portable Media Player fixes
    * Miscellaneous fixes
    * New: [ml_pmp] Synchronization the Media Library with your portable media player
    -» Compatible with iPod, Creative, and Microsoft Plays For Sure devices
    * New: [enc_aacplus] Coding Technologies aacPlus High Bitrate encoder available in Winamp Pro
    * New: [enc_aacplus] aacPlus (HE-AAC) in MP4 container
    * New: [enc_aacplus] Using Coding Technologies encoder for LC-AAC
    * New: [in_mp3] gapless MP3 playback
    * New: [installer] multi-user profile options
    * New: [installer] remembers your previous installer settings
    * New: [in_wave] in_wave 3.0
    * New: right-to-left playlist display
    * Improved: new ATF functions and tags
    -» $fill(x, count) - creates a string with x repeated count times
    -» $lpad() - same as $pad, but adds padding to the left
    -» $decode(...) - switch/case function. example: $decode($fileext(%filename%),MP3,MPEG-1 Layer 3,MP4,MPEG-4 Container,Other)
    -» $IfStrEqual(string1,string2,result) - if string1 and string2 are equal, displays result. case insensitive
    -» $IfStrEqual2(string1,string2,result,else) - if string1 and string2 are equal, displays result, otherwise displays else. case insensitive
    -» %folder% - top level folder name of the file
    * Improved: Stereo beat visualization for modern skins
    * Improved: [in_midi] provides metadata to media library
    * Improved: [in_mod] provides metadata to media library
    * Improved: [in_mp3] unicode id3 tags
    * Improved: [in_mp3] preliminary id3v2.4 support
    * Fixed: broken playlist sorting
    * Fixed: playlist problems with multi-line tags (e.g. %comment%)
    * Fixed: shuffle with only one song in playlist
    * Fixed: ghost seek slider appears if Winamp loses focus during seeking
    * Fixed: video options from video window right-click context menu
    * Fixed: playlist winshade international character support
    * Fixed: fullscreen video display international character support
    * Fixed: [enc_lame] bit reservoir
    * Fixed: [enc_lame] cutoff of last frame
    * Fixed: [gen_ff] GDI Object leak with Current Skin prefs page
    * Fixed: [in_midi] not following winamp's title formatting options
    * Fixed: [in_midi] reset button blocks further access to config
    * Fixed: [in_mod] not following winamp's title formatting options
    * Fixed: [in_mp3] incorrect version identification (showed 5.18 in 5.12)
    * Fixed: [in_mp3] incorrect information shown for AAC+ files
    * Fixed: [in_mp3] reading incorrect id3 comment tag
    * Fixed: [in_mp3] sometimes failing to read last id3 frame
    * Fixed: [in_mp4] loss of album art when modified metadata
    * Fixed: [in_vorbis] not following winamp's title formatting options
    * Fixed: [in_vorbis] registry usage (now multi-user profile safe)
    * Fixed: [in_wave] 32bit floating point WAV playback distortion
    * Fixed: [in_wm] changes made with Attribute Editor not updating in ML/Playlist
    * Fixed: [vis_milk] missing files from distro (you can stop bugging us now, Rovastar
    * Fixed: [vis_milk] 100% cpu usage when paused
    * Updated: [enc_lame] LAME 3.97b2
    * Updated: [gen_ff] FreeType 2.1.10
    Downloads
    Winamp 5.2 Full
    Betanews.com
    Softpedia.com
    Winamp 5.2 Lite
    Betanews.com
    Softpedia.com
    » ASUS A7V266-MX 1.03A :: AMD Duron Applebred 1.6 DHD1600DLV1C 1593@1992 Mhz (2189+) :: 2x256 Mb RAM PC2100 133@166 Mhz «
    » Philips 170S6FS/78 17" LCD 1280x1024x32@75 Hz :: S3 UniCrhome IGP 16 Mb OnBoard «
    » Seagate ST3160021A 160 Gb & Maxtor 6E040L0 40 Gb :: LG CD-RW GCE-8525B 1.03 52x32x52x & LG DVD-RAM GSA-4165B DL03 :: SevenTeam ST-420BKV 2.0 420W «
    » 3DMark00 ~ 9353 :: 3DMark01 ~ 9052 :: 3DMark03 ~ 4162:: 3DMark05 ~ 1672 :: Aquamark03 ~ N/A :: GL Excess ~ N/A :: Super Pi 1M ~ 0.59.641 «
  2. Avatar de Gargula
    Gargula é offline Pure Gamer! Gargula está em um caminho distinto
    Data de Entrada
    Aug 2005
    Local
    Porto Alegre - RS
    Mensagens
    15.715
    Eu uso a versao antiga do Winamp. 5. alguma coisa.
    Quando sair a versao final eu baixo
    Dragon Serie: AMD Phenom II 955 3.2Ghz B.E. - (Zalman CNPS9500) - ASUS M4A79T-Deluxe - OCZ 2x2Gb DDR1333 - Sapphire ATi 4890 Vapor-X 1GB GDDR5 - HD Seagate 160GB SATA II - HD Maxtor DMP9 80GB (externo / Akasa Integral case) - Seventeam 700W EAD - LCD Samsung 931bw 19" 2ms HDCP - Case Chieftec BH - CoolerMaster Musketeer - Samsung DVD-R/RW 18x - X-Fi Xtreme Gamer Fatal1ty Pro - SO Windows Seven x64 - Logitech X-230 2.1 - Microsoft LX 3000 - Microsoft Wired KB 500 - Mouse A4Tech X7 - Logitech Rumblepad 2
    [ Adrenaline.com.br > Super Moderador ]
  3. Avatar de DanadS
    DanadS é offline wazuuuuuupppp :P DanadS está em um caminho distinto
    Data de Entrada
    Dec 2005
    Local
    Brasília - DF
    Mensagens
    1.968
    aff não aguento mais v esse nome "BETA" aehuaehuae
    Campanha de exclusão digital: Devolvam a internet aos Nerds, bando de Noobs!
  4. Avatar de Maurivillas
    Maurivillas é offline Boo'ya Moon, babyluv! Maurivillas está em um caminho distinto
    Data de Entrada
    Feb 2005
    Local
    São Bernardo do Campo
    Mensagens
    10.800
    Só instalei por causa da segurança, pois o som do Winamp é mais forte do que o do WMP.
    Na minha opinião, ele está igual à versão anterior.
    Até
    Phenom II 940 X4 -> 4 GB 1066MHz (7-7-7-20) -> Asus M3A78 -> Samsung HD080HJ -> Barracuda ST3320620AS -> DVD-RAM GSA-H42N -> DVD SH-S203D (Sata) -> Mouse Razer Diamondback -> HIS Radeon HD4870 -> Samsung 931BW --> All powered by 7team 420w
    [ Adrenaline.com.br > Redator > Moderador > Hardware > Placas de Vídeo > Geral > Papo Cabeça ]
  5. Avatar de MrDuckGod
    Data de Entrada
    Feb 2005
    Local
    Curitiba
    Mensagens
    1.664
    Para quem utiliza a versão 5, vale apena, pois foi corrigido muita coisa e fechou brechas de segurança. To usando aki e está bem estável.
  6. Avatar de healer
    healer é offline Peugeot 207 healer está em um caminho distinto
    Data de Entrada
    Apr 2005
    Local
    Recife
    Mensagens
    6.858
    Winamp is the best
    Intel E8600 ES @ 4.3Ghz cooled by Noctua NH-U12P | NVIDIA GALAXY GTX 285 1GB | Seagate 2x500GB 7200.12 RAID + 1 TB Backup
    eVGA FTW 750i | 2X2GB G.Skill DDR2 1000 mhz 5-5-5-12 2.1v | Samsung 2233RZ 22" 120hz | Zalman ZM850-HP 850W
    Plantronics GameCom 777 USB Gaming Headset | RAZER Lycosa gaming keyboard | Cooler Master Centurion 5
    Mouse Microsoft 1.1 with Steel QcK Pad | Gravador Pionner 111-D | Internet GVT 15MB
Informações do Tópico
Usuários Navegando no Tópico
Existem atualmente 1 usuários navegando nesse tópico. (0 membros e 1 visitantes)
Tópicos Similares
  1. Winamp 5.36.1500 Beta Preview 1
    Por MrDuckGod no fórum Área Windows
    Última Mensagem: 22/08/2007, 19:37
  2. Winamp 3.34.1239 Beta
    Última Mensagem: 06/04/2007, 13:30
  3. Winamp 5.34.1178 Beta
    Última Mensagem: 17/03/2007, 01:01
  4. Winamp 5.34.1155 Beta
    Por MrDuckGod no fórum Periféricos e Acessórios
    Última Mensagem: 15/03/2007, 01:12
  5. Winamp 5.33.1079 Beta
    Última Mensagem: 08/03/2007, 23:33
Permissões
  • Você não pode criar novos tópicos
  • Você não pode responder mensagens
  • Você não pode anexar arquivos
  • Você não pode editar suas mensagens
