+ Responder o Tópico
Mostrando resultados 1 até 3 de 3
  1. Avatar de MrDuckGod
    MrDuckGod é offline Mr. DuckGod MrDuckGod está em um caminho distinto
    Data de Entrada
    Feb 2005
    Local
    Curitiba
    Mensagens
    1.664
    Winamp 5.34.1155 Beta
    - New: IPv6 support
    - Improved: Made installer delete in_mp3pro :/
    - Improved: IPC_CONVERTFILE now uses api_decodefile (for ripping & transcoding)
    - Improved: Embedded IE pages now run in a separate thread
    - Improved: General speed and performance optimizations
    - Improved: [in_wave] Added ATF support for %bitrate%
    - Improved: [ml_local] Composer / Album view (in Edit View, Filters tab)
    - Fixed: ???? in the taskbar & system tray with Unicode titles (note that many third party plugins will cause this to revert back to ????)
    - Fixed: Installation of Sonic Engine on systems with other Sonic/Roxio products
    - Fixed: Tab orders in Preferences
    - Fixed: Various media library accessibility/focus issues
    - Fixed: [enc_lame] Better output samplerate selection for transcoding
    - Fixed: [enc_wav] WAVs missing first 11 samples
    - Fixed: [gen_ml] Keyboard focus issue
    - Fixed: [in_cdda] Long artist/albumartist CD Info bug
    - Fixed: [in_cdda] Crash on Winamp exit after playing Audio CD
    - Fixed: [in_cdda] CDDB crash-on-close bug
    - Fixed: [in_dshow] potential crash on corrupt/malformed media files
    - Fixed: [in_mp3] Memory leak when retrieving info for .aac files
    - Fixed: [in_vorbis] Album tag removed when using ml 'edit selected items'
    - Fixed: [in_wm] Crash when trying to burn WMA files
    - Fixed: [ml_local] Composer tag not saving with 'Edit Info'
    - Fixed: [ml_local] Total size not showing up in local media views
    - Fixed: [ml_local] Possible duplicate entries on upgrades after rescanning folders
    - Fixed: [ml_local] (No Album Artist) & (No Publisher) sometimes displays no results
    - Fixed: [ml_local] Sorting Album pane by Year
    - Fixed: [ml_local] isempty/isnotempty for querying empty/populated fields
    - Fixed: [ml_pmp] Possible crash when deleting a group of songs containing non-sequential duplicates
    - Fixed: [ml_pmp] "haven't" typo in prefs :-D
    - Fixed: [pmp_p4s] Launching Winamp on device insertion not working
    - Fixed: [pmp_p4s] No longer creates .alb files on devices that don't support it
    - Updated: in_vorbis to libvorbis 1.1.2 and libogg 1.1.3
    - Updated: in_flac 2.0 (based on FLAC 1.1.4)
    - Updated: MusicIP Mix (formerly Predixis MusicMagic) v1.1
    - Updated: Sonic Ripping/Burning Engine v3.6.36.500
    Download:
    - Winamp 5.34 Beta Full
    - Winamp 5.34 Beta Pro (asks for key during install)
    - Winamp 5.34 Beta Standard (same as Full but no ML or viz)
    - Winamp 5.34 Beta Lite
    » ASUS A7V266-MX 1.03A :: AMD Duron Applebred 1.6 DHD1600DLV1C 1593@1992 Mhz (2189+) :: 2x256 Mb RAM PC2100 133@166 Mhz «
    » Philips 170S6FS/78 17" LCD 1280x1024x32@75 Hz :: S3 UniCrhome IGP 16 Mb OnBoard «
    » Seagate ST3160021A 160 Gb & Maxtor 6E040L0 40 Gb :: LG CD-RW GCE-8525B 1.03 52x32x52x & LG DVD-RAM GSA-4165B DL03 :: SevenTeam ST-420BKV 2.0 420W «
    » 3DMark00 ~ 9353 :: 3DMark01 ~ 9052 :: 3DMark03 ~ 4162:: 3DMark05 ~ 1672 :: Aquamark03 ~ N/A :: GL Excess ~ N/A :: Super Pi 1M ~ 0.59.641 «
  2. Avatar de Leon
    Leon é offline Gamer Leon está em um caminho distinto
    Data de Entrada
    Aug 2006
    Local
    Mensagens
    5.350
    Tem previsão de quando lança o full??
    PC: AMD Phenom II X4 955 Black Edition | ASUS M4A79T Deluxe | Corsair XMS3 DDR3 2x 2GB | Sapphire ATI Radeon HD5770 1GB | Maxtor 500 GB + Seagate 250 GB | Seventeam ST-550P-AM ASM | Windows 7 Ultimate x64
  3. Avatar de MrDuckGod
    Data de Entrada
    Feb 2005
    Local
    Curitiba
    Mensagens
    1.664
    Citação Postado originalmente por leo. Ver Mensagens
    Acho q vc quis dizer final... Bom, é provavel que no máximo 2 semanas já esteja sendo disponibilizado para download.
Informações do Tópico
Usuários Navegando no Tópico
Existem atualmente 1 usuários navegando nesse tópico. (0 membros e 1 visitantes)
Tópicos Similares
  1. Winamp 5.36.1500 Beta Preview 1
    Por MrDuckGod no fórum Área Windows
    Última Mensagem: 22/08/2007, 19:37
  2. Winamp 3.34.1239 Beta
    Última Mensagem: 06/04/2007, 13:30
  3. Winamp 5.34.1178 Beta
    Última Mensagem: 17/03/2007, 01:01
  4. Winamp 5.33.1079 Beta
    Última Mensagem: 08/03/2007, 23:33
  5. Winamp 5.2 Beta
    Por MrDuckGod no fórum Periféricos e Acessórios
    Última Mensagem: 01/02/2006, 18:26
Permissões
  • Você não pode criar novos tópicos
  • Você não pode responder mensagens
  • Você não pode anexar arquivos
  • Você não pode editar suas mensagens
