+ Responder o Tópico
Mostrando resultados 1 até 11 de 11
  1. shokerlol é offline WTH! shokerlol está em um caminho distinto
    Data de Entrada
    Jun 2007
    Local
    Foz do Iguaçu
    Mensagens
    68
    A M2N68 aceita os novos Phenom II??
    Quero saber se AM2+ e AM3 eh a mesma coisa ou se eh praticamente a mesma. e que vou trocar meu processador da signature por um Phenom II, mas ele eh AM3 e minha placa eh AM2+.
    Specifications
    CPU
    AMD Socket AM2+ / AM2 Processors
    for AMD Phenom? FX / Phenom / Athlon? / Sempron?
    AMD Cool'n'Quiet? Technology
    Chipset
    NVIDIA nForce 630a
    System Bus
    2000/1600 MT/s
    Memory
    4 x240-pin DIMM, Max. 8 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
    Dual Channel memory architecture
    Due to AMD CPU limitation, DDR2 1066 is supported by AM2+ CPU for one DIMM per channel only. Please refer to www.asus.com or user manual for Memory QVL.
    When installing total memory of 4GB capacity or more, Windows 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
    Expansion Slots
    1 x PCIe x16
    2 x PCIe x1
    4 x PCI 2.2
    Storage
    Southbridge
    1 xUltraDMA 133/100/66/33
    4 xSATA 3 Gb/s ports
    NVIDIA® MediaShield? RAID Support RAID 0,1,0+1,5,JBOD span cross Serial ATA drives
    LAN
    NVIDIA nForce built-in Gigabit MAC with external Realtek 8211CL PHY
    Audio
    8 -Channel High Definition Audio CODEC
    - Optical S/PDIF out port at back I/O
    - Support Jack Detection and Multi-streaming
    USB
    10 USB 2.0 ports (6 ports at mid-board, 4 ports at back panel)
    ASUS Unique Features
    ASUS Express Gate:
    1. Access the Internet in 5-second* boot time without entering Windows
    2. A built-in OS offers instant fun platform for Internet and Instant Messenger!
    3. Friendly Picture Manager Interface
    * The actual boot time is subject to hardware configurations and product models.
    ASUS Quiet Thermal Solution:
    - ASUS Q-Fan
    ASUS EZ DIY:
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 2
    Special Features
    ASUS AI NET 2
    ASUS MyLogo 2
    Back Panel I/O Ports
    1 x PS/2 Keyboard port(purple)
    1 x PS/2 Mouse (green)
    1 x LAN (RJ45) port
    4 x USB 2.0/1.1 ports
    1 x Parallel(Printer) Port
    1 x Optical SPDIF out
    1 x COM Port
    8-channel Audio ports
    Internal I/O Connectors
    3 x USB 2.0 connectors support additional 6 USB 2.0 ports
    1 x Floppy disk drive connector
    1 x IDE connector
    4 x SATA connectors
    1 x CPU Fan connector
    1 x Chassis Fan connector
    1 x Power Fan connector
    1 x Chassis Intrusion connector
    1 x CD audio in
    1 x 24-pin ATX Power connector
    1 x System panel connector
    1 x S/PDIF Out connector
    1 x Front panel audio connector
    4-pin ATX 12V Power connector
    BIOS
    8 Mb Flash ROM
    AMI BIOS, PnP, DMI2.0, WfM2.0, ACPI2.0a, SM BIOS2.5
    Accessories
    1 x UltraDMA 133/100/66 cable
    1 x SATA cable
    1 x SATA power cable
    1 x I/O Shield
    User's manual
    *Note: The floppy disk drive cable is purchased separately.
    Support Disc
    Drivers
    ASUS PC Probe II
    ASUS Update
    Anti-virus software (OEM version)
    Form Factor
    ATX Form Factor
    12 inch x 9.25 inch ( 30.5 cm x 23.6 cm )
    vlw
    Athlon X2 5200 2.7Ghz || ASUS M2N68 || XFX 9800GT DDR3 512MB || Markvision 2GB 800Mhz || Maxtor SATA II 320GB || Gabinete Satellite L590 || Monitor LG Flatron W1942S "19" || Windows XP SP2
  2. Avatar de fanatic
    fanatic é offline JesusNomeSobreTodoNome fanatic está em um caminho distinto
    Data de Entrada
    Jul 2005
    Local
    Cidade Maravilhosa
    Mensagens
    840
    pode colocar tranquilo qualquer processador AM3 nesse mobo que ela suporta!
    [AMD] X2 4000 - [ASUS] M2N68 - [KINGSTON] 2GB - [XFX] 8800GTS (G92) - [SAMSUNG] T220
  3. KEM
    KEM é offline Usuário Registrado KEM está em um caminho distinto
    Data de Entrada
    Jun 2005
    Local
    Santos e São Paulo
    Mensagens
    335
    Só não vai poder usar DDR3, pois sua placa só tem slot para DDR2...
    Referencias:
    Mercado Livre / ForumClass / Antigo ForumGDH
    HardMob: DE-SP, Claudio Pena, hyper_intel, jok7, Waco, Urucum, NEO, Matrix´s Lord, Riot_Control, Great Man, Kersul, Jabasan, lightravem , vlsantos, 286DX20, karaskis, Stratus_FGH, doc.jordan, #PILANTRA#, Alemão_SP, James_Bond_007, Pardal05, Ø ©@®@, Pianista, drmg, Ricardo.vivas, trevas, caemilord, mmarcelocsouza, Tiago_MS, Moheekan, Salin_muchiba, Maxdil, 3,14k2|P1k4chu, jorge luis de almeida lar, joearny, Cristiano Silva, etc...
  4. Avatar de Paradise Lost
    Paradise Lost está online agora Usuário Registrado Paradise Lost está em um caminho distinto
    Data de Entrada
    Feb 2006
    Mensagens
    3.239
    existem placas mãe da Asus que suportam CPU AM2 e AM3?
    fase do Crysis dedicada a mim, o Paradise Lost:
    http://www.adrenaline.com.br/forum/a...1&d=1199066050
  5. KEM
    Data de Entrada
    Jun 2005
    Local
    Santos e São Paulo
    Mensagens
    335
    Citação Postado originalmente por Paradise Lost Ver Mensagens
    Toda placa mãe AM2+ na teoria tem que aceitar CPUs AM2, AM2+ e AM3...
    Referencias:
  6. Avatar de joaodopet
    joaodopet é offline Usuário Registrado joaodopet está em um caminho distinto
    Data de Entrada
    Dec 2007
    Local
    Vitória - ES
    Mensagens
    3.457
    Sim, as placas AM2+ suportam tanto AM2/AM2+, como AM3, só que você não vai poder usar memórias DDR3 devido a mobo só possuir slots DDR2. Já numa mobo AM3, ela só aceita processadores AM3, e com memos DDR3.
    Abraços
    PC1: Sempron 2500+, GA-K8VM800M, 1Gb DDR400, Geforce 6800XT, HD 40Gb Ide, Fonte 450W
    PC2: Athlon X2 4000+ @ 2,7Ghz + Watercooler , GA-MA69VM-S2 , 2Gb DDR2667 , Hd 160Gb Sata 2 , Foxconn 9600GT 655Mhz/1820Mhz , Huntkey 350W
    PC3: Sempron LE1150, Gigabyte GA-M61PME-S2, 1Gb DDR2 667Mhz, Geforce 8600GT XXX, HD250Gb Sata 2
  7. Avatar de Paradise Lost
    Data de Entrada
    Feb 2006
    Mensagens
    3.239
    então os AM3 rodam com DDR2.
    OK, valeu pela informação.
  8. Avatar de joaodopet
    Data de Entrada
    Dec 2007
    Local
    Vitória - ES
    Mensagens
    3.457
    Sim, sem problemas, o que não ocorre é o inverso
  9. KEM
    Data de Entrada
    Jun 2005
    Local
    Santos e São Paulo
    Mensagens
    335
    As CPUs AM3 tem controladora de memoria DDR2 e DDR3... Vai depender só do suporte da placa mãe a um dos tipos de memoria...
    Referencias:
  10. shokerlol é offline WTH! shokerlol está em um caminho distinto
    Data de Entrada
    Jun 2007
    Local
    Foz do Iguaçu
    Mensagens
    68
    teoricamente placa AM2+ e cpu AM3 são compativeis, mas o q quero saber mesmo éh se o desempenho vai ser comprometido, aquele negocio q vcs chamam de gargalo, poderiam me explicar direito isso?
    vlw
  11. Avatar de Maurivillas
    Maurivillas é offline Boo'ya Moon, babyluv! Maurivillas está em um caminho distinto
    Data de Entrada
    Feb 2005
    Local
    São Bernardo do Campo
    Mensagens
    10.819
    Citação Postado originalmente por shokerlol Ver Mensagens
    vlw
    Comece a usar a procura do fórum pra ver se sua dúvida já não foi respondida:
    http://adrenaline.com.br/forum/cpu-s...a-vga-cpu.html
    Phenom II 940 X4 -> 4 GB 1066MHz (7-7-7-20) -> Asus M3A78 -> Samsung HD080HJ -> Barracuda ST3320620AS -> DVD-RAM GSA-H42N -> DVD SH-S203D (Sata) -> Mouse Razer Diamondback -> HIS Radeon HD4870 -> Samsung 931BW --> All powered by 7team 420w
    [ Adrenaline.com.br > Redator > Moderador > Hardware > Placas de Vídeo > Geral > Papo Cabeça ]
Informações do Tópico
Usuários Navegando no Tópico
Existem atualmente 1 usuários navegando nesse tópico. (0 membros e 1 visitantes)
Permissões
  • Você não pode criar novos tópicos
  • Você não pode responder mensagens
  • Você não pode anexar arquivos
  • Você não pode editar suas mensagens
